#TIDGEY Posted November 7, 2016 Posted November 7, 2016 Anyone had experience with 7Twenty Wheels and the quality of them? looking at getting these at somepoint, fitment looks pretty decent for the glanza, whats peoples thoughts? Cheers Quote
redz11 Posted November 8, 2016 Posted November 8, 2016 A load of the drift guys i know have 7twenty wheels and theyre fairly good by the looks of them Quote
#TIDGEY Posted November 8, 2016 Author Posted November 8, 2016 (edited) much arch work, many scrubs...Too wide ? Any other wheel suggestions and good fitments that dont require archwork.. besides RPFs Edited November 8, 2016 by #TIDGEY Quote
funny onion Posted November 9, 2016 Posted November 9, 2016 Nah the width is OK, it's the offset that's the problem. The fronts you could fit aftermarket wings, but the rear you'll really struggle with.... I've not experimented with a glanza that much but on the other starlets any offset below about ET20 on an 8j rim you will struggle on the back. Stiff coilovers and no epic lows, panhard rod, bit of camber on the front (1.5 degrees give or take), 195 tyres and you could get away with 8j ET20 without much work but any lower offset is just going to eat the tyres/arches unless you run massive arch gap haha. Quote
#TIDGEY Posted November 12, 2016 Author Posted November 12, 2016 Nah the width is OK, it's the offset that's the problem. The fronts you could fit aftermarket wings, but the rear you'll really struggle with.... I've not experimented with a glanza that much but on the other starlets any offset below about ET20 on an 8j rim you will struggle on the back. Stiff coilovers and no epic lows, panhard rod, bit of camber on the front (1.5 degrees give or take), 195 tyres and you could get away with 8j ET20 without much work but any lower offset is just going to eat the tyres/arches unless you run massive arch gap haha.Cheers for the advice,found some XXRs which are far more suitable, ET21 4x100 15"x8" Quote
Ollieh17 Posted November 12, 2016 Posted November 12, 2016 Bear in mind also 8j wheels( i had rotas 8j et20) made the car drive like shit, felt slow and sluggish. Lighter smaller wherls changed it alot Quote
