As mentioned in a previous post my sunroof is leaking now badly. It's filling the headlining on the car and water is running down the inside of both the windscreen and the rear window. I can't find where it's leaking from or how to fix it. Someone previously suggested something about drain holes for the sunroof but I can't even find any. I have a 98 sr any help would be much appreciated as I don't want my car rotting from the inside out.
Theres usually a pipe that comes off each corner 2 run down the front A pillars and the rear 2 go down the b or C pillars.
You might need to pull the trim off to find them to trace them but they will be there
I was hoping it wouldn't be. Looking at the line it's empty so if it is blocked it's at the top.
Posted Image
Any advice/suggestions on how to remove the headlining?
Sent from my F5121 using Tapatalk
Is that red bit a joiner? Could stick the airline on there and either blast out the blockage or listen for where the air is escaping up top. Even better would be smoke if there's no blockage but I'm not sure how you'd do that lol
