Danz_ep95 Posted December 28, 2016 Posted December 28, 2016 Hi all I'm doing my auto to manual conversion on my 4paw are the auto shafts same as manual and I've got abs on mine will that be an issue cheers Quote
glanzadude Posted December 28, 2016 Posted December 28, 2016 shame you dont leave the auto in it as i had great fun in my auto when i had it Quote
Danz_ep95 Posted December 28, 2016 Author Posted December 28, 2016 shame you dont leave the auto in it as i had great fun in my auto when i had it Quote
roachburger Posted January 1, 2017 Posted January 1, 2017 the shafts should be the same. the only real difference apart from brake pipe plumbing between abs and non-abs is the rings on the cv joints or on the back of the disks at the rear.i know from experience abs/non-abs cv joints are the same you just knock the abs ring off.and the rear disks just don't have them on its even machined to fit one.so i doubt abs will effect shit you may just have to knock a ring off. with regards to the shafts.. most car companies won't make different shafts for the autos and manuals because of cost and the way they are built in huge batches.it all just bolts on as one, hubs, shocks, shafts, disc etc.. (i think at each bay on the production line they have 2-3 minutes to perform a task.)i did an auto-manual conversion on my 205 because the autos had lower compression engines for turbo fun and I didn't even separate the shafts from the wheel hub.Just out and straight back into a manual box, not saying its the same but, stands to reason. Quote
Danz_ep95 Posted January 1, 2017 Author Posted January 1, 2017 the shafts should be the same. the only real difference apart from brake pipe plumbing between abs and non-abs is the rings on the cv joints or on the back of the disks at the rear.i know from experience abs/non-abs cv joints are the same you just knock the abs ring off.and the rear disks just don't have them on its even machined to fit one.so i doubt abs will effect shit you may just have to knock a ring off. with regards to the shafts.. most car companies won't make different shafts for the autos and manuals because of cost and the way they are built in huge batches.it all just bolts on as one, hubs, shocks, shafts, disc etc.. (i think at each bay on the production line they have 2-3 minutes to perform a task.)i did an auto-manual conversion on my 205 because the autos had lower compression engines for turbo fun and I didn't even separate the shafts from the wheel hub.Just out and straight back into a manual box, not saying its the same but, stands to reason.I see mate thanks for clearing that up for me will have a try and see how it goes Quote
