ep82paul Posted January 8, 2017 Posted January 8, 2017 Hi all recently I have had both rear calipers off while changing disk and pads I had the brake pedal pushed Down to the floor so brake fluid didn't pass all over put it all back together bled all the air out and pedal still goes to the floor if I pump the pedal a few times it gets hard let go for literally 2 seconds and goes back to the floor but when pedal is on the floor you can't turn the disk am puzzled with it think I cud off popped the seals in master cylinder and will a UK starlet one fit cheers Quote
gorganl2000 Posted January 9, 2017 Posted January 9, 2017 i know the ep91 and ep82 brake master cylinders are interchangeable...as i did it last yearhowever, just double check the BMC size (its stamped on the unit itself)...because i know the turbo ep91 and some turbo ep82 are 13/16 and some turbo ep82 are 7/8 i dont know anything about the n/a models BMC sizes or servo at all...hopefully others can help you in that area Quote
