Hi, I am currently running 285bhp with a 2.75inch strait pipe, Im booked on at rockingham an there sound limit is 98db.
My question is I'm guessing this ig going to be over the limit an what is the best/quickest way of silencing it down?
Thanks Neil
Oh right where can i grab one lf these from an this will not effect the performance?
You can get a screw in silencer for your backbox. Will require a small hole for it
If you've got time between now an Rockingham to have a silencer fitted, then do so.
A proper silencer not something you stick in the end of the exhaust
Thats ace. Cheers thanks alot lad!
The in tip silencers can also effect your map too!
So be careful.
