Chrscrr5 Posted February 17, 2017 Posted February 17, 2017 Need someone to help asap, deum brakes on na starlet wont come undone? Quote
morgey Posted February 17, 2017 Posted February 17, 2017 Usually a lip formed, if you look on the back of the drum theres a little slot sometimes with a rubber grommet over it. Remove that and you should see a little gear/wheel you can wind that in to draw the shoes in a bit to help release that past the lip. Of if youre not worried get a big ol hammer and knock them off Quote
adzy Posted February 17, 2017 Posted February 17, 2017 Or take the hub nut of then put the wheel back on so you have something to grip to pull and wiggle it off Quote
