glanzanut22 Posted March 1, 2017 Posted March 1, 2017 So before I took the 71 off the road to change the turbo, the clutch started slipping. Then a few days later I lost the pedal. The pedal biting point in nearly at the floor. I have an exedy 3 puk coming this week, however I'm concerned it might be the master cylinder as well? Although this would seem pretty coincidental with the clutch slipping. Any thoughts as to what could be going on?CheersIan Quote
gorganl2000 Posted March 2, 2017 Posted March 2, 2017 did you check the clutch slave cylinder to see if its leaking?how does the fluid look in the master cylinder? ---clear or dirty/black? Quote
glanzanut22 Posted March 2, 2017 Author Posted March 2, 2017 did you check the clutch slave cylinder to see if its leaking?how does the fluid look in the master cylinder? ---clear or dirty/black?I changed the slave mate as it was leaking anyway mate. The oil in the reservoir looks clear. Quote
