Kealenc Posted March 6, 2017 Posted March 6, 2017 Just after putting a 4efte into my ep91 starlet and for some reason isn't starting, it is sparking well but for some reason won't run. Car seems to be trying hard to actually start but there is something funny going on with the fuelling. Just wondering if the starlet fuel pump is OK for the turbo engine and should if I need to change the map sensor?Any help/advice greatly appreciated 👍 Quote
RobSR Posted March 6, 2017 Posted March 6, 2017 Fuel pump will be okay but i would recommend putting a new waldron in anyway. Yes you will need to change the map sensor. Quote
