Hi guys.
Does anyone know the torque for the Whiteline Anti-lift kit (the 4 M12 cap heads)? It says to torque to standard spec which I think is 155nm as standard bolt is marked as '10' on the head. I don't want to break the captive nut on the inside of the chassis and cause an absolute nightmare.
Thanks.
Edited by StanMan
According to this it's 155nm? They are 12.9 cap heads. But originally M12 Toyota flanged bolt marked with a 10 on the head.
Edited by StanMan
I found my EP70 chassis manual 87Nm value for that bolt, should be almost same as newer model.
Great, thanks for that. I did it to 80Nm in the end, so not far off.
Your welcome :) I mostly trust my own hands and feeling only. Using torque tools only in some important engine bolts and nuts. Trust Yourself :D
