Alrite lads / lasses,
Fitting myblive sports front bumper soon. So what im after is some pictures of them fitted and ideas for extra mounting points. The worry is running fibre glass wings the front bumper might pit too much stress on them.
Any suggestions?.....
I have no pictures showing the mounting points but mine was just screwed in to the wings and had 2 bolts in the slam panel (where there's usually 4 clips holding the grill in place)
Cheers for the info guys.
I takenit you made brackets for the cross member? Just concerned about the weight on the wings
The original bumper has holes that line up with the holes on the slam panel. Our bumpers have these holes marked so you'll just need to drill them out. There are tabs that rest on the bumper bracket just under the headlight so all the weight is not on the wings.
