Gtbadboy2016 Posted May 2, 2017 Posted May 2, 2017 Giving my gt some in 3rd it 😐 I hit redline I changed gear it went pop shot some white smoke out the back. And started bogging like a car in limp mode. There's no smoke at all. I've done a compression test there very low not even 2bar of compression on cylinder 1 and 2. 3 and 4 are fine.. Any suggestion what it could be. Thanks appreciate it Quote
Gtbadboy2016 Posted May 2, 2017 Author Posted May 2, 2017 Thanks mate appreciate it. Will give that a try and see if that is the cause.someone else has said the same thing. Im guessing the heads got to come off no matter what.. Quote
patman Posted May 2, 2017 Posted May 2, 2017 It has mate but rather that then something even worse like rings 👍🏻 Quote
Gtbadboy2016 Posted May 3, 2017 Author Posted May 3, 2017 Na your right mate.. You deffo think its head gasket. Quote
