Cyanidesid Posted May 24, 2017 Posted May 24, 2017 When I put the key in the door it will lock both doors but won't open both doors and also the switch on the drivers door does the same Quote
Nafeez2125 Posted May 25, 2017 Posted May 25, 2017 I think its a negative trigger for the central locking. whats happening is that there is a common ground that supply the locking side and unlocking side. in your case its not getting ground signal in the box behind the foot well to lock the car. bad contact maybe. Quote
Cyanidesid Posted May 26, 2017 Author Posted May 26, 2017 Ok thanks when I push on the dash it unlocks so i must me an earth Quote
