gaztop101 Posted May 31, 2017 Posted May 31, 2017 does anyone know how much i expect to pay to have new valve guides fitted on my starlet 4e-fe , n/a cylinder head, fitted new valve stem seals but still smoking only when started up after being left overnight, think its the guides that must be worn, cheers Quote
Ollieh17 Posted May 31, 2017 Posted May 31, 2017 probably cheaper and easier to buy a different head/hole engine. Measure the valve guides up and see if they are worn Quote
gaztop101 Posted May 31, 2017 Author Posted May 31, 2017 they are worn because theres side ways movement from the valves in the guides, cant seem to find any recon heads anywhere Quote
SpikeyJp_68 Posted June 2, 2017 Posted June 2, 2017 Around 100 pounds parts and labour. Any machine shop should be able to do it. Delicate and quite a time consuming job as with any head work Quote
