carlosd87 Posted June 19, 2017 Posted June 19, 2017 Trying to dismantle my wing mirror to re paint, but haven't difficulty getting the mirror off, any ideas or know how's? Cheers Carl Quote
richglanzav Posted June 19, 2017 Posted June 19, 2017 If its an electric adjustable mirror then turn ignition on, use mirror adjustment switch to adjust it to full 'up' position (so there is as big of a gap as possible at the bottom of the mirror seperating the mirror itself and the casing). Then use a small flat head screwdriver and VERY gently wedge/pull it off from the bottom. There are two clips holding it on to the plate inside the casing, and they just need popping off then the top two can be wiggled off. But use extreme care lol its a fiddly bastard of a job and I would reccomend a glove incase you are a heavy handed bastard and break your mirror (speaking from experience). Quote
