Squeak-Glanza Posted April 7, 2008 Posted April 7, 2008 Hi am going to be fitting my Sard fpr tomorrow and im needing to no what pressure to set it at?I have a hks adjustable actuator and front mount on and im wanting to be running .8 bar.Also will this stop ma car hitting fuel cut???squeak Quote
StarletRick Posted April 7, 2008 Posted April 7, 2008 it wont stop fuel cut. and if youre running a stock turbo, set it to about 35 psi with the vacuum hose off. that should sort you out for .8 Quote
Squeak-Glanza Posted April 8, 2008 Author Posted April 8, 2008 cheers for that... this mite sound stupid but wat vacuum hose do i take off Quote
StarletRick Posted April 8, 2008 Posted April 8, 2008 the one that goes into the top of the fuel regulator. Quote
StarletRick Posted April 8, 2008 Posted April 8, 2008 np mate. let me know if you need any more help. Quote
liam2368 Posted April 9, 2008 Posted April 9, 2008 where abouts can you get the gauge for these? i never got one with my car the fpr was already on the car though and i want to make sure it has the correct pressure, could another gauge be used? Quote
StarletRick Posted April 9, 2008 Posted April 9, 2008 get them on ebay for about 20 quid. just make sure it has a 1/8 NPT thread. Quote
Glanza_Ragger Posted April 14, 2008 Posted April 14, 2008 I set mine with the vacum attatched, allthough even with it disconnected its exactly the same Quote
Squeak-Glanza Posted May 21, 2008 Author Posted May 21, 2008 Just fitted the sard fpr and with the vacum off its 26psi and with the vacum on its sits at 35psi what is right or are they both rite... Quote
