Zak.p Posted July 15, 2017 Share Posted July 15, 2017 Looking at a guide to rotate td04 says about welding actuator on after rotating guessing I don't need to do this if I'm externally gated? Stupid question still new to all of this lol, cheers Quote Link to post Share on other sites
akyakapotter Posted July 15, 2017 Share Posted July 15, 2017 Hey bud you need to remove the massive C-clip from the compresser housing its a bugger remove then the little metal dowle with a pair of pliers. then remove the clamp holding it all together split the turbo and rota the cartrage 180 and refit all to suit. cheers nick. Quote Link to post Share on other sites
Zak.p Posted July 15, 2017 Author Share Posted July 15, 2017 Thanks mate will give it a go today, so I don't need to get the actuator welded back on if externally gated or I still do? Cheers zak Quote Link to post Share on other sites
akyakapotter Posted July 15, 2017 Share Posted July 15, 2017 On 7/15/2017 at 7:02 AM, Zak.p said: Thanks mate will give it a go today, so I don't need to get the actuator welded back on if externally gated or I still do? Cheers zak no bud but you do need the wategate flap welded shut. Cheers Nick. Quote Link to post Share on other sites
Zak.p Posted July 15, 2017 Author Share Posted July 15, 2017 Sweet mate cheers for the help Quote Link to post Share on other sites
Zak.p Posted July 15, 2017 Author Share Posted July 15, 2017 Got the actuator removed and the clip, defo doesn't want to come off very easily lol may have to soak overnight if no luck with rubber mallet again Quote Link to post Share on other sites
