just put a glanza inlet on my SR. it struggles to start sometimes and when it does start up, the engine management light will flicker on randomly and it will dip on power like completely and sometimes even stall. it's undrivable. it also makes a small chirping sound under load at certain rpm which i've never heard before? this to me suggests an air leak/vaccuum leak. would i be right in changing to the rubber hoses?
Any help would be greatly appreciated as this is really frustrating me. 👍
Make sure you have gaskets on the inlet + throttle body, all tightened up properly, also check you have connected pipes to the correct places 👍🏻
