00joeindastarb0 Posted August 7, 2017 Posted August 7, 2017 You can convert it using the original Ecu and loom if you splice a few wires. For the box and associated parts just use an NA if a GT isnt available.
Starlet__SR Posted August 8, 2017 Posted August 8, 2017 I'm sure the only thing you need to alter on the electrical side is the neutral switch.
danblp Posted August 8, 2017 Author Posted August 8, 2017 Could do with a mk3 loom to use quadlights aswell
