Just got car back from having td04 & wepr ramhorn kit and few other bits fitted but dump valve was still left connected and was still dumping instead of the screamer & w/gate, have removed & blocked off the dump valve but screamer still not working, Any suggestions?
(Have got bottom air ports on w/gate plugged apart from 1 which a hose goes to turbo& all top ports open) Cheers
The dump valve can stay connected mate, the screamer pipe will only open when you reach the desired boost pressure, which in your case would be spring pressure, hope this helps!
Sent from my iPhone using Tapatalk
Edited by Sefton-EP91
Ooh ok sweet thanks thought the dump valve couldn't be used together with the external w/gate and Screamer! Ideal cheers mate
^^ crazy talk :p
Dumpvale releases inlet side pressure
Wastegate releases exhaust gas pressure
