  • 3 months later...
  • 5 weeks later...
if the jets were changed, look at the sizes written on them. If you are referring to the idle fuel screw, send it all the way in( dont over tighten) and back it out one and a half turn, that is a good starting point. also make sure the float level is set correctly.
