Ep82gi Posted September 23, 2017 Posted September 23, 2017 Been using these a good couple of months now and since first fitting they have pushed out the back of the d bracket now should I worry and consider using white line instead or do you think they will be okay.? Thanks Liam Quote
5e colin Posted September 23, 2017 Posted September 23, 2017 (edited) i have the original test kit ( white bush ) it does the same it wont get worse then that just keep an eye on play ( clean often ) is it me or the angl;e of the pic but your bush retaining bracket looks angled ??? Edited September 23, 2017 by 5e colin Quote
Ep82gi Posted September 23, 2017 Author Posted September 23, 2017 Thank Colin your a star always around to help :-) and I think it's the angle of the picture to be fair hard to get a close up as it's decked on 14s Sent from my iPhone using Tapatalk Quote
Ollieh17 Posted September 25, 2017 Posted September 25, 2017 when fitting them did you tighten the d bracket up with the car off the ground or on the ground? Quote
