I'm about to make a wiring loom for my standalone ECU, and wondered if anyone had any ideas what terminals I need to buy for some of the factory plugs.
Coil packs, distributor, coolant temp sensor, TPS, etc.
I've found some replacement plugs that come with terminals, but I already have the plugs, so it's just the terminals I'm after.
I also stumbled across these (https://www.efihardware.com/products/2558/Toyota-EFI-Pin-Kit-1) but Australia based, and the shipping is daft.
Ta.
I wouldn't know the brand, but the terminals will be all the same (brand) for the parts you're looking for.
Make sure you get terminals with the same surface finish as that of the component you're mating to, ie tin plating, silver etc.
