turbominicooper Posted November 23, 2017 Posted November 23, 2017 yo, anyone used the headgasket from this kit in a performance engine - https://japserviceparts.co.uk/toyota-starlet-gt-turbo-ep82-head-gasket-set-made-in-japan-4e-fte.html they sent the kit down accidentally instead of the oem one i ordered. not sure if it will hold beans with my 5e td04 build, what do you think - any good? cheers Quote
Ollieh17 Posted November 23, 2017 Posted November 23, 2017 Bet they are the same as the toyota ones. Any sign of a make on them? AJUSA etc Quote
turbominicooper Posted November 23, 2017 Author Posted November 23, 2017 8 minutes ago, Ollieh17 said: Bet they are the same as the toyota ones. Any sign of a make on them? AJUSA etc ill have a close look later see if i can spot one Quote
turbominicooper Posted November 24, 2017 Author Posted November 24, 2017 On 11/23/2017, 11:16:12, Ollieh17 said: Bet they are the same as the toyota ones. Any sign of a make on them? AJUSA etc Only marking on it says "117" Quote
Ollieh17 Posted November 24, 2017 Posted November 24, 2017 If you paid for oem I'd expect oem. But likelihood the gaskets are made in the same place as toyota Quote
