damdrifting Posted January 6, 2018 Posted January 6, 2018 Hi everyone, I finished my 4e-fte swap in my corolla EE90. The engine start very well but after 5-6 seconds it stalls ... I wanted keep accelerated to maintain the engine speed , but nothing changed . The engine stalled again . i have checked if there were air intake : nothing Can you advise me ? Default code , dirty idle control valve ? Quote
AlbertaBeef Posted July 8, 2018 Posted July 8, 2018 If it stalls due to a very low idle, and the code is a dirty idle control valve, I'd definitely clean the idle control valve. =D also, there's an idle speed adjustment screw on the intake, right side on the back-side (nearest the vehicle firewall) under a little round rubber cover about 1cm round. You may have to play with that to get your best idle. Quote
lukEp Posted July 8, 2018 Posted July 8, 2018 (edited) What ECU are you running? Sounds like an engine immobiliser is kicking in. Edited July 8, 2018 by lukEp Quote
