Hi. I'm new and I've been looking through threads on builds for doing a na-t conversion and I'm amasing parts now. With regards management I couldn't see a decisive winner.
Piggyback an N.A. loom with det3
Get an fte loom and ecu.
I'm thinking an fte loom and ecu would be plug and play. Am I correct or can someone poke me in the best direction based on experience
This is going to run low boost 6psi so don't need anything major.
Thanks
It's not plug and play unless you change everything, dash loom, clocks, stalks...... but it's doable to just mod the standard dash loom to plug into the glanza ECU.
Edited by lukEp
Ah ok. Is it the same plug combination on both ecu's?
Plus does the na map sensor  sufficient for low boost?
Edited by Mark
More detail
