Forged pistons, Valve springs and 3e flywheel WANTED!
Forged pistons
Performance valve springs
3e flywheel/ 5e clutch conversion so I can use 4efte clutch
decent clutch!
2 hours ago, Johnny said:
I've got a set of Weisco 74.5 pistons and Scat Rods that I don't need now £450.
Need 5e rods but how much for just pistons?
Been speaking to you mate not sure I want one that’s been modified
but what power did your xtd 6puc girding stage 3 handle? And was it 212mm or 200mm?
And did you use that flywheel pal?
Just bought same xtd clutch but 200mm but wondering if it will hold now, what do you think? And do you know how much stock 5e can handle?
5efe 10 psi
5efhe 1.1bar thats pushing the pistons to max  ringland failure follows soon  rods upto 1.3/1.4bar
So it works fine and drives nice?
What will the 5efe make on a td04 at 10psi that’s what I’m going to be putting it up to and will it be safe at that?
Pistons seperate £280 delivered. They will need new rings as they are used.
rods £220 delivered.
2 hours ago, 5e colin said:
200mm no the torque will kill it  212mm yes
tdo4 on 5e is like ct9 ish 4efte
What power do you think td04 on stock 5e 10psi make do you think pal
Around 200 I think depends on health of engine to if I was you stop looking. At the bhp nrs and concentrate on your torque you gain lots of it try sourcing a acis manifold to make the tdo4 spool even faster by 300 to 500rpm
Acis all the way to redline !!!!!!
