Willd35 Posted June 22, 2018 Posted June 22, 2018 Hi, I’m currently running a standard manifold and a few other small mods that makes my car hit fuel cut high up in the revs, if I put on a new manifold will it make my engine hit fuel cut earlier on as it’s less restrictive? Cheers! Quote
H_D Posted June 22, 2018 Posted June 22, 2018 Its the factory ecu causing fuel cut. Nothing to do with the mani. Quote
Willd35 Posted June 26, 2018 Author Posted June 26, 2018 On 22/06/2018, 17:46:32, H_D said: Its the factory ecu causing fuel cut. Nothing to do with the mani. I know pal I’m just thinking the manifold de restricting it will have better air flow so will it make it hit fuel cut earlier on Quote
