Hi i ve a problem with my car, glanza engine swapped in a ep81.
The car was running well.
Now , when i turn key on i ve no light on dash and no starter.
Only warning lights, horn, High lights.
Could you guys help me ? Where should i source the issue?
Thanks
New problem now : battery light stays on when car is running. Turn off the key, turn on again and no power at all. Efi fuse keeps blowing up :(((
Thanks. One more question :  i ve distributor ox and knock loom all together and its added to the main loom.
They are all shield and they end in a Orange connector where ground wires but they are cut.
Can i ground  the shielding on the châssis ?
What happens if the shielding arent grounded?
Is it something to worry about or no importance ?thanks
