looking at this last night to order new fittings, the rail feed adaptor at the end is 8 mm and i have a an8 fitting for it, the return line is 6 mm so do I need a an6 fitting and 6mm internal diameter fuel line for the return and 8mm internal for the feed ? :)
13mm thread is a very odd size as per that picture. I’ve never seen a m13 > an-6 adapter unless they have their measurements wrong.
With all due respect, I wouldn’t fit that regulator to my car. I’d source a genuine Sard/FuelLab/Aeromotive etc that you can also get the correct fittings for. It’s not worth cutting corners on something that maintains a fuel supply..
