Lewis124 Posted January 2, 2019 Share Posted January 2, 2019 (edited) Anyone able to shed some light on this I've got a 98 glanza v that every keeps getting code 34 (turbo pressure) light come on when I’m driving ? somethimes the car will sorta bog down for a split second when it comes on and sometimes it won’t do anything and still light comes on ? I've been looking though a few different feed and some people are saying it could be the fuel cut but I want to be sure before I do anything. the car it’s pretty much standard apart for it’s got a cat back exhaust and a differen air fillter but that’s still in the stock place any suggestions would be great cheers ! Edited January 2, 2019 by Lewis124 Spelling Quote Link to post Share on other sites
RobSR Posted January 2, 2019 Share Posted January 2, 2019 Does sound similar to fuel cut, do you have a boost gauge so you can see what its reading? Also check your vac lines on your actuator dont have any splits/breaks in them. Quote Link to post Share on other sites
Lewis124 Posted January 2, 2019 Author Share Posted January 2, 2019 Thanks for the reply I don’t have a boost gauge but I did just go for a drive and put the it in low boost and it didn’t seem to do it so I’m going to guess it was fuel cut. But I will check the vac lines anyway Quote Link to post Share on other sites
RobSR Posted January 4, 2019 Share Posted January 4, 2019 On 1/2/2019 at 1:48 PM, Lewis124 said: Thanks for the reply I don’t have a boost gauge but I did just go for a drive and put the it in low boost and it didn’t seem to do it so I’m going to guess it was fuel cut. But I will check the vac lines anyway Expand Yes its worth giving it a check over. Try and get a boost gauge if you can too so you can see what its doing. Quote Link to post Share on other sites
Lewis124 Posted January 5, 2019 Author Share Posted January 5, 2019 Okay I’ll get on that cheers mate Quote Link to post Share on other sites
