gwtaylor Posted March 15, 2019 Posted March 15, 2019 Should the front anti rollbar be this close? Quote
rob_bower Posted March 17, 2019 Posted March 17, 2019 seen a few people have this problem with thick arb’s hitting lower arm mounts I had some spacers made which I might have somewhere. But those droplinks need tightening up. Quote
gwtaylor Posted March 17, 2019 Author Posted March 17, 2019 1 hour ago, rob_bower said: seen a few people have this problem with thick arb’s hitting lower arm mounts I had some spacers made which I might have somewhere. But those droplinks need tightening up. Cheered rob I didn’t even notice they needed tightening as I bought it as a project best get it checked and go tighten every bolt wherr would the spacers go? Quote
rob_bower Posted March 17, 2019 Posted March 17, 2019 Yea the droplinks definitely wants tightening up. I’d also check that lower alk bush as there shouldn’t be that much of a gap. The spacer sits under the arb to chassis mount to drop it down the same amount as the alk plate. Quote
Di_Bodi Posted March 19, 2019 Posted March 19, 2019 Here it is my thicker TRD one - tight but never knocked Should have it painted before fitting!! I have the spacer plates made up and fitted at the same time when fitting anti-lift kit. No knocking luckily! and the TRD bar still not painted...:(( laziness! at least it's undersealed now Quote
