Devs313 Posted March 21, 2019 Posted March 21, 2019 (edited) Guys, are any of you running turbosmart 2 bolt wgs with your Td04 WEPR setups? Just about to place an order with Sacha and he has a 2 bolt flange for Tial 2 bolt wg setups - which should fit my turbosmart wg - but just wanted to double check?? Sacha is not 100% certain so I said I would check with the Uk members first. Thanks Edited March 21, 2019 by Devs313 Quote
gorganl2000 Posted March 21, 2019 Posted March 21, 2019 https://www.verociousmotorsports.com/Shop-by-Category/Wastegate-Flanges-and-Gaskets/Vibrant-35-38mm-Wastegate-Flange-Outlet-Untapped may be that site can help...you can draw your own conclusions from there ---see dimension diagram and "type" Quote
Devs313 Posted March 21, 2019 Author Posted March 21, 2019 Thank you. Apparently its a universal fitting for all the 2bolt type, so I should be ok. https://honda-tech.com/forums/welding-fabrication-53/wastegate-flange-options-2987382/ Quote
