Hey, can anyone upload some pictures of how they have wired their fogs up, whether it is the wires to the switch, or wires from the fogs to whatever power source your using - such as the sidelights?
any help appreciated- cheers
Lukey 'B'
if you dont have them as standard. then you need to take a live from the sidelights and then use that with a switch to power the fogs.
so when you do want them on, theyll only come on with the lights.
so is that one wire from each of the sidelights? can the n/a "button" (where the hi/lo boost should be) be used as a button?or do i actually need to buy something? or can i sort of knock it out lol
mate use the live from under the dash. then run that to both fog lights.
its really really basic electrics. if youre not comfy with it, get a sparky to do it. itll take them 15 mins.
going to have to attempt it... hopefully it will work - how do i get the live wire from the engine bay to under the dash?
stand infront of the engine bay and on the fire wall u'll see a rubber grommit thing with wires comin through it! that leads into the engine bay.
also, where the hi/lo button would be, thats not a button, its a blanking piece of crap. try to get another rear window heater switch or hazard switch as it fits PERFECTLY rather than bodgin some piece of crap in there.
Phil.
