1990timeismoney Posted April 29, 2019 Posted April 29, 2019 Hi all.looking to buy a 38mm wastegate for my turbo setup.along with any advice on the correct spring to run 1bar. Thanks luke
RobSR Posted April 30, 2019 Posted April 30, 2019 Spring pressure depends on turbo setup and engine spec etc? Hard to say without knowing more.
1990timeismoney Posted May 1, 2019 Author Posted May 1, 2019 Hi thank you for they reply.will be running blitz ECU and a td04 or the TF035 turbo. intercooler fpr etc its currently running 1bar with the td04 on standard wastegate
