chrisp96 Posted May 25, 2019 Share Posted May 25, 2019 Hi folks would anyone know what voltage it should be for the 4 pin plug at distributor I'm getting 0.6v on each pin is that right? Quote Link to post Share on other sites
Stu Posted June 13, 2019 Share Posted June 13, 2019 Hey dude, There isn't any voltage supplied to the 4 pin distributor plug, there are reluctor pick ups on the triggers inside that create voltage back to the ecu in a wave form. Cranking and idle its common to have somewhere around 0.5v and at peak rpm somewhere up around 6v. Quote Link to post Share on other sites
Stu Posted June 13, 2019 Share Posted June 13, 2019 You really need to check the waveform with an oscilloscope. Quote Link to post Share on other sites
