HennyD Posted June 17, 2019 Posted June 17, 2019 been a few weeks and my ep91 has been having issues. car is cutting out and making allot of pops and bangs around 5k rpm under load, in neutral its fine, wont go past 5k tpm without misfiring or over fuelling. cant tell what the issue is. please help asap Quote
maerijn Posted June 18, 2019 Posted June 18, 2019 whats your setup, everything stock or did you change anything? Quote
HennyD Posted June 18, 2019 Author Posted June 18, 2019 280bhp+ 430cc injectors. Its a td “stage 2” build so has td04 turbo Quote
RobSR Posted July 3, 2019 Posted July 3, 2019 Sounds like a miss, so check the basics first, i.e ignition system. What management is the car running too? When did the problem start occurring? Did you change anything from when it was ok, or did it start happening randomly? Quote
