Foxxface Posted July 7, 2019 Posted July 7, 2019 The mileometer on my glanza is not working, but the trip is. Can that be a faulty cable if one is working and the other isn't? Is it more likely that I need another mechanism (if you can actually get them replaced)? Any advice gratefully received. Thanks in advance. Paul Quote
H_D Posted July 13, 2019 Posted July 13, 2019 There is only 1 cable for both check its connected properly on the back of the instrument cluster. Quote
Foxxface Posted July 29, 2019 Author Posted July 29, 2019 Thanks for your reply H_D. I checked and the speedo cable was connected properly. So I thought I'd take the whole thing out and see if there was anything preventing the dial from turning. I removed some of the dirty grease from around the cogs and spindles and put everything back. Took it out for drive and it now works, so am well pleased. There must just have been a bit of dirt stopping the top set of spindles from turning. Quote
