Hi guys , I’m having a problem with my car and want some advice off people. When I’m driving , for example 20mph in second , if I let off the accelerator the car jerks/violently jumps back & forth , the same happens if I press the accelerator straight after letting off it. I’ve got a few ideas what it could be , rear gearbox Mount or bad accelerator cable or adjustment, any help appreciated.
sounds like an ignition issue, had similar symptoms on mines but went away after changing the ignition leads,
