Giannis Posted August 28, 2019 Posted August 28, 2019 What s the differences between glanza v and starlet na (servo and brake master cylinder) Quote
RoyalDutchie Posted November 21, 2019 Posted November 21, 2019 (edited) The glanza non abs and brake booster from na starlets build between 1996 and 1997 are the same(OEM 44610-10370). If their is a true difference between abs and non abs boosters I do not know, they do have different OEM numbers. The internals of the master cylinder are also the same between glanza s/v and the na both for non abs and abs. The only parts that might be different is the reservoir since the glanza has rear disc brakes thus should require a bigger reservoir to feed the rear brakes (they do have a different oem number). Another member might be able to clarify this. Edited November 27, 2019 by RoyalDutchie Quote
Giannis Posted December 28, 2019 Author Posted December 28, 2019 On 11/21/2019 at 9:08 PM, RoyalDutchie said: The glanza non abs and brake booster from na starlets build between 1996 and 1997 are the same(OEM 44610-10370). If their is a true difference between abs and non abs boosters I do not know, they do have different OEM numbers. The internals of the master cylinder are also the same between glanza s/v and the na both for non abs and abs. The only parts that might be different is the reservoir since the glanza has rear disc brakes thus should require a bigger reservoir to feed the rear brakes (they do have a different oem number). Another member might be able to clarify this. Thanks for reply Quote
