Shane Barham ✯ Posted November 9, 2019 Posted November 9, 2019 Glanza v vf12 turbo lost all boost car drives fine just no boost? main causes? thanks Quote
RobSR Posted November 9, 2019 Posted November 9, 2019 Checked all your intercooler pipes are still together and no noses have split? Quote
Shane Barham ✯ Posted November 9, 2019 Author Posted November 9, 2019 On 11/9/2019 at 8:04 PM, RobSR said: Checked all your intercooler pipes are still together and no noses have split? Expand all hoses and intercooler pipes look good runs and drives fine just no boost/power smokey once warm valve stem seals need replacing I believe but nothing to do with the boosting issue Quote
Shane Barham ✯ Posted November 9, 2019 Author Posted November 9, 2019 On 11/9/2019 at 10:59 PM, RobSR said: Are you running an external Wastegate? Expand yes thinking could be fully open? Quote
RobSR Posted November 9, 2019 Posted November 9, 2019 You’d hear it if it was; it could be that if your original turbo had an internal Wastegate that had been welded/held closed for use with the external one this could have come undone. Quote
Shane Barham ✯ Posted November 10, 2019 Author Posted November 10, 2019 On 11/9/2019 at 11:50 PM, RobSR said: You’d hear it if it was; it could be that if your original turbo had an internal Wastegate that had been welded/held closed for use with the external one this could have come undone. Expand firstly was not boosting now it is boosting but really late and over boosting! Quote
