I've recently brought a civic half rad for the glanza and before I go to fit it I was reading that some people get the bottom hose outlet moved over but I also see that it will go with out it. So is best to get it moved or just not bother ??
i moved my bottom pipe on the civic radiator to match the stock hose position and it works fine that way.
i know others that just ran the civic radiator as it is (just pulled the stock bottom hose across and pushed it on) and they ran fine with no issues
so it seems either way, there are no issues once the coolant flows properly (no hose kinks, etc)
