Boylo99 Posted May 10, 2020 Posted May 10, 2020 Just looking to get some info really ive bought an lsd box but has no shafts so what im asking is whats different from what i can see itll be the longer drivers side shaft will shorter due to the oem lsd and the shorter passenger shaft would be the same for both ? Quote
akyakapotter Posted May 11, 2020 Posted May 11, 2020 I believe only one is shorter you'll have a job finding one. Did it come with all the mounts aswell as some of those are different also need a 2 part sandwich plate. Cheers nick Quote
Boylo99 Posted May 11, 2020 Author Posted May 11, 2020 Yeah i thought the shorter passenger one was the same length but the longer driver one is shorter we have cut one of the longer shafts down i have the rear mount but need the dust cover Quote
