stanwithstarlet Posted May 26, 2020 Posted May 26, 2020 (edited) hi all, new owner of a starlet GLS 5door, when turning sharp left there is a knocking noise. what should i look at? driveshaft? ball joint? if you were going constantly left around and around its almost like clockwork knocking. thanks in advance for any advice. edit: noise is from front right Edited May 26, 2020 by stanwithstarlet Quote
BurtEP82 Posted May 27, 2020 Posted May 27, 2020 You’re right with driveshaft. Classic symptom of outer CV joint 👍🏻 Quote
stanwithstarlet Posted May 27, 2020 Author Posted May 27, 2020 thanks burt, when you say outer... wheelside? Quote
