Ep71T Posted October 26, 2020 Share Posted October 26, 2020 Hey Guys My current setup is Koni Yellow and Eibach springs. I modified them by inserting a 2cm spacer inside the strut housing and the tightening the lower mounting bolt to get some more travel from the suspension.. I came across a set another Koni yellow setup but this time its from a corolla ZZE121. I like the fact that the front one have thicker piston and I was wondering If anyone has used strut inserts from another car with success. I will have to modify the strut housing from the ZZE121 in order to fit the EP7 and at the same time maybe I will make a threaded sleeve for some custom spring rates. Any ideas? 😊 Quote Link to post Share on other sites
Ep71T Posted November 12, 2020 Author Share Posted November 12, 2020 Also thinkig that since i have new control arms to just put a 6mm ot larger spacer instead of the anti lift kit for now. Again any ideas or comments 😀? Quote Link to post Share on other sites
