Change the headlights on the glanza.
I've had a look this morning and cannot get the blood one out. Drivers side there is a little bit of room, i've taken the plug off the bulb but cannot get it out. Huge rubber cap round it. Does this come off as i couldn get it to move? Does the bulb twist through the cap?? help??
Also with the passenger side i cannot get my donkey paws in but do i need to take the resonator box of to get it out.
the rubber cap pulls back around the wire, underneath the cap you will see a little wire clip which needs unhooking, similar principle to how a safety pin works, after thats uncliped the bulb and holder will just be loose so you can pull it out ( but be gentle ) and change the bulb :p
