FruitNinjaXYZ Posted January 31, 2022 Posted January 31, 2022 Hi, I want to turbo my UK na starlet. I've been looking to do it for a while now and have seen mixed opinions on which setup you should use (depending on budget ofc). Is a td04 turbo better on a na starlet than a ct9 due to the higher compression? Not looking for huge gains, just a bit more poke with some reliability! - Also if anyone has a kit for sale let me know! Planning to use a det3 ECU along with other support mods (intake, exhaust etc). Any other info is appreciated! Thanks Quote
Sam44 Posted January 31, 2022 Posted January 31, 2022 (edited) There are quite a few 4efe+t recently on the eP91 build page ranging from big money to good budget builds have a look. Most of the lads and lasses/ladets on the first 2 pages are active on here and give some great advice. Good lads. You will typically wait around 1 week for a reply. Edited January 31, 2022 by Sam44 Quote
FruitNinjaXYZ Posted February 15, 2022 Author Posted February 15, 2022 On 1/31/2022 at 3:37 PM, Sam44 said: There are quite a few 4efe+t recently on the eP91 build page ranging from big money to good budget builds have a look. Most of the lads and lasses/ladets on the first 2 pages are active on here and give some great advice. Good lads. You will typically wait around 1 week for a reply. Yeah I've been following a few including yours as you provide alot of info, thank you 👍 But I'm trying to find out how some people get about with the knock sensor? Did you drill/tap out the block to fit it or is there another way round it? Thanks Quote
Sam44 Posted February 15, 2022 Posted February 15, 2022 (edited) Mine has the hole and it's already threaded. My 4efe. It would be wise to clean up the threads with a tap. Edited February 15, 2022 by Sam44 Quote
