hey guys i juts got all the parts together for my engine rebuild how ever i just need to ask 2 more questions
in an early post i asked about the torque settings for the head bolts in the repy i was to to torque them in order
so question1: what is the order when replacing head bolts
question 2: what size on my filler gauge would i use to set the tappets ?
thanks guys
the 4e has overhead cams, it doesnt have tappets, it used over-bucket shims, which should be fine if you are using stock cams.
the head bolts are in 2 stages and bolt out in a star pattern from the top centre.
ill try to find you a diagram, because i cant remember off the top of my head.
once again thanks rick
that diagram would be greatly apreciated
the best thing to do is buy a corrolla haynes manual, that has a 4efe engine.
and all the torque settings and diagrams, and how to's are in there.
i found this book a great help, when working on the engine
the 4efte and 4efe engines are almost identical, the only things being different are the pistons and rings.
