you will have to do the wiring mate if its an aftermarket tacho
its usually four wires..........
red = a switch 12v (something that only comes on when the ignition is turned)
black = earth
white = dash lights (for the back light)
green = rpm signal/ ignition coil (which can be taken from the diagnostics box)
its not major difficult really but you will need to know a little about wiring.
Nice one mate? what sort of places u rekon wud do this?
Hmm i no a lil bit lol,
wired in a mp sub n 6x9s, and put a switch in a circuit for my led 6x9 covers?
lol
i no what your saying, but not sure where i would put the wires exactly, i no where you are talking about for each of them , but not sure where i would put the wires if u understand?!?
Got any pics??
no pics mate im afraid. the best way to do it is to wire in near your fuse box under the drivers side. ie, find the fuse for the headlights and follow the wires.
if you buy the tacho it will more than likely have fitting insructions to help you out.
the wires will need to be spliced into other wires
you may be best taking it somewhere if your not sure. im sure places that fits alarms or car sterios may do it.
