hey just wondering if there is any advantage/disadvantage to fitting a V 'box into an N/A?
does it have shorter gears for better acceleration or anything? trawled these forums and cant find an answer!
thanks guys :)
The N/A gearbox is what makes it a good car anyway, Its got closer ratios than the Glanza's which make 0-60s alot more fun... :)
  • 2 months later...
  • 2 weeks later...
n/a's can hit, as near as makes no difference 60 in second aswell.
what you really want to do, is put the corolla 6 speed in there....
N/A setups need shorter gear ratios to work well, take Honda for instance CRX Vtec will only do about 90 mph @ 6000 rpm in 5th <_<
