Marc Posted May 19, 2008 Posted May 19, 2008 I found this gizmo in my glanza tonight which explains why when boosting at 1bar i wasnt hitting fuel cut. I beleive there is a difference between this and the HKS FCD as it doesnt lean out the fuel curve, is this correct/ And if so does this mean that the car will fuel itself properly if i was boosting at a bar?Any help appreciated. Quote
Callan Posted May 20, 2008 Posted May 20, 2008 the JAM fcc(bcc) is a similar device to the hks item but i think the jam doesnt lean the car out unlike the hks,plus the jam is pre set,i have a jam bcc and its perfect for 1.1+barand no it wont up your fueling for 1 bar,you will either need to get rid of your jam fcc and buy a jam-blitz-toms etc ECU to do that,or buy a fpr,safc or emanage etchope this helps Quote
StarletRick Posted May 20, 2008 Posted May 20, 2008 got it in one cal. all the FCC does is remove the limiter, it doesnt adjust fueling. anything over 12 psi and youll need to start tweeking the fuel. Quote
montanajr Posted May 20, 2008 Posted May 20, 2008 You might as well rip it off and sell it to me for a fiver Marc mate... Quote
ecksjay Posted May 20, 2008 Posted May 20, 2008 the FCD leans out the fuel curve over the ENTIRE rev/boost range, even if you were only idling for example, whereas the FCC only actually functions once you've hit 0.93bar (i.e level of fuel cut), at which point the ECU will only be fuelling to support 0.93bar, even if you're boosting well above that. However, at any level lower than 0.93bar, your fuelling should be fine.you'll need an safc at the least to sort your fuelling out. a cheaper old model (i.e 5 knob unit) would be ideal, would only need half hour on the dyno. Quote
